Hi all,
Knocking out 3m cavity load bearing wall for remaining upper block work, roof and assume extension roof (not the the full span), joists run parallel therefore upstairs weight remains supported elsewhere. UC are going to sit on the inner skin of the remaining block work on padstones, on knocking out noticed concrete lintel (deep) for a pipe 5-6 courses deeper than the DPM. This lintel spans for a single pipe 200mm.
The concrete lintel is close but not directly under the cavity wall and will not bear the weight as it's not considered as a point load, however the concern is with the structure of brick work being triangular will it be unaffected?
For example, really quick sketch up:
Cavity wall ||
Concrete Lintel ===
Talking to SE he is unbothered and suggests with it being five courses deep and running the other direction it shouldn't need to be taken into consideration.
Cavity wall ||
Concrete Lintel ===
