- Joined
- 21 Dec 2010
- Messages
- 6
- Reaction score
- 0
- Country
Hi
i'm just about to start knoking through a new doorway from the existing kitchen into a new utility room built on the side of the house (the utility has a bedroom above too.
The wall is a double skin brick wall, no cavity.
the wall is the old external wall to the house, and supports the ends of the ceiling/floor joist of the old bedroom above on the inside, and the floor/ceiling joists of the new bedrrom above on the "outside".
what type of lintel should i use, there are approx 4 or 5 courses of bricks above where the lintel will be and the underside of the joists,
i was thinking of a couple of 6" concrete lintels, one either side?
also, should i support the walls above with akro props, or will i get away with just taking the bricks out and installing the lintels, waiting for everything to set, THEN knocking the dorway out?
thanks all
thanks all
