Liquid Dpm over concrete/bitumen
22 Oct 2012
Nottinghamshire
Looking lay a liquid dpm in the cellar floor followed by a self levelling compound as it uneven.
Old coal cellar, half is decent concrete but the other half has a bitumen type coating already.
Any recommendation on products to use- most I've found say only suitable for concrete, I've only found multi tite 2k suitable for both but it's not cheap
Thanks for any suggestions
CharlieB1981, good evening.
Suggest you have a look at the "Pinned Posts" in floors stairs and lofts?
In there there is a section on exactly this topic?
Ken.
Already did, the pinned posts over suggestions and tips on how to lay them, which doesn't answer what I'm after- i.e. Products that you can use over concrete and bitumen
1st you need to remove the old adhesive
Then grind floor smooth or latex screed it smooth with the right compound.
Then a coat of liquid dpm at 350 microns
Then prime & screed again
