I have a 3 zone boiler system with a bladder tank on the makeup side and on the upstream side of the zone valves. The problem: zone valve shuts-large back pressure causing pipe shaking and noise. The tank is new with 12 lbs. factory set pressure. Should I put additional pressure in tank? There appears to be about 15 lbs showing on the temp/pressure gage. This pressure backup has broken one cast iron zone manifold. Thank you.
Ron
Ron
