Locating Hard to Find Leaks
17 Apr 2009
Sussex
Just thought of a way.
If you have a region of roof where you need to know exactly where the leak is coming from you can divide the roof say into 8 parts and hose each one in a different colour water.
8 packets of dye (tile grout die perhaps), using the darkest colour at the lowest of the eight regions, and working progressively upwards to the lightest colour and topmost region.
Would need bucket hose pump.
Then you can tell where the leak is from the colour of the interior stain and repair the right bit.
Another way is to get a bendy camera and stick it through a light socket.
Oh, Thank you so much for the suggestion. Actually, I had the same issue with my kitchen roof 3 years ago but I contacted Austin Roofers even I contacted many Roofing Company in Austin for this issue they came and inspected then they found the main area where my roof leaked and they replace that with a new one. and now I have no such kind of problem.
Another way is to get a bendy camera and stick it through a light socket.[/QUOTE
How would you control dyed water so it did not mix leaving you none the wiser.
