D
Deleted2797112
Been up in the loft in my new house getting it ready to top up the insulation and put down some boards for storage. There are 3 aerials taking up most of the loft space! One is a very large upside down T shape with the head of the T screwed to a crawl board - it's tubular maybe 8mm diameter - it's a bit of a hazard as the leg of the T sticks up vertically to just about the level of my eyes. The cable disappears under the insulation. The second is just lying flat on top of the insulation - it's a conventional looking aerial with a swivel type support leg also lying flat but no longer secured to anything - screws lying loose. The cable also disappears under the insulation. The third is a smaller more modern looking affair which is tied to the rafters. It has two cables one white and one brown which run along the rafters in different directions and disappear under the insulation.
I'm pretty sure the third one feeds an aerial connection in one bedroom - I can see the white cable running away from it inside a wardrobe which fits with where the white cable is in the loft. I suspect the brown cable on the third aerial might also supply the only other two sockets in the house but can't be sure. I would really like to get rid of the unused (if any) aerials or try to hang them if I can't.
My question is about how to test them - is the only way to do it to disconnect the cable from the two aerials in turn and see whether the TV reception on either of the two sockets disappears?
Also, is it possible that they're daisychained together - I have no idea if that is something that would ever be done but I want to make sure I cover all bases before I start removing anything.
Many thanks in advance!
