Loft boarding for storage
24 Sep 2008
Manchester
hi, have read many posts about whether ppl's joists are strong enough to convert their lofts into storage spaces, and still none the wiser.
my joists are 1.5x3" with a pitch of about 15.5 to 16" - plus there's some extra 3x1" planks/battens? spaced at about 44" pitch over the top.
tried to show in this pic:
http://www.dereksdontrun.com/pics/loft1.jpg
another shot, if it's any help:
http://www.dereksdontrun.com/pics/loft2.jpg
this suitable for light storage (only thinking of old diy-stuff, boxes of crud and bits/bobs (certainly not habitable or accessed more than a couple times a year)? biggest span, no idea - on the 1st floor there's a wall running practically down the middle of the property, so think the middle should be ok, at least?!?
I've bought a load of the 320x1220x18mm tongue & groove loft panels from Wickes. I understand I want to lay them on the joists, 90 degrees to them, but what do i do about the existing 3x1" planks? do i just do a botch job and fill in the gaps between them and have an uneven floor, remove/replace with the tongue & groove, or what?
look forward to any info, cheers.
Putting your boards down on the existing and using it as light storage won't be any problem at all.
cheers for reply, but what should i do about the 3x1" cross-beams already on the top of the joists?
lay flooring between them (resulting in an uneven finish), remove them and lay the tongue & groove loft-panels over then entire area, or what?
any ideas?
They are binders, which give intermediate support to the joists. If you're just using it for storage, leave them in and put up with the occasional step-up in the floor level: to do anything else will require joist strengthening and all of a sudden you're moving towards a "proper" loft conversion.
By the same token, putting additional timbers in to level up to the top of the binders will add weight to the structure as a whole and kick more load onto the binders, which they won't take.
