hello guys - i am forum virgin who needs some advice. I am currently in the process of making my loft into a room - not a full conversion. We have a baby on the way and my computer room and records will now have to be evicted to the loft space as we only have a two bedroom. This is what we plan to do.
1. raise floor and add boards
2 install velux window
3 add power sockets and lights
4 add loft ladder
5 insulate and board under the tiles (not floorboards)
my main concern, as in all loft spaces is the ventilation and the problems with condensation- obviously the loft is hot in the summer and cold during the winter months. I would like to get the roof to a constant comfortable temperature - i also dont want my records and computer to melt
My rafters under the tiles are quite small only around 3 to 3 " thick - directly under the tiles in some kind of sheeting material - its not felt- the house was built in the 50's. I plan to attach a batten to the underside of this material along the rafters to give me the 50mm gap that i need for ventilation. I will then use 25mm celotex or kingspan as insulation between the rafters and then on top of the rafters use a foiled back plasterboard to make the room look attractive and more homely. As i have a velux window and will leave a small gap around the edge of the floorboards plus i intend to get new soffits with vent holes -do you think this will be able to keep the condensation away. Your help will be hugely appreciated. rgds Hillbilly
4 add loft ladder
