As I understand it, because I'm achieving 30 mins fire protection via the existing ceiling rather than any structure reliant on the new steel beams for their integrity I don't need intumescent paint.
Having just carried 450kg of unpainted steel into the loft this morning, I'm wondering whether it should be painted to protect against corrosion or for any other reason?
It's been drilled and sat outside so has some surface rust, but presumably once it's dried off and fitted it's not going to sit there slowly rusting in the warm dry loft, so would be fine as it is.
Does that sound OK, or should I get some paint on it?
Cheers
Cheers
