Hi
I am looking to install down lighters in the ceiling of my new loft.
I have 100mm PIR insulation just above the Plasterboard, then a 50mm (min) void above that, and then the plywood roof.
BC plans spec low energy lighting.
Is this going to be possible, have been looking at LED low profile down lights ... can these b embedded in insulation, as they dont generate that much heat.
I also want an electric shower, I assume this need protecting on a 40a 30mA RCD circuit, there is no room on my existing consumer unit for this, is it best to replace the unit entirely - or split the tails and have an additional unit installed.
I understand any metal objects in a bathroom need to be earthed, does an electrician need to come in to certify such an earth connection ?
