L
llewop
I'm converting my garage into a dining room and want to install 6 down lights. I was going to cut out the holes and just loop the down lights together but then realised I have loft insulation between the ceiling and the room above. I have noticed you can get dowlighters that come with a plastic casing round them (the lamp is totally enclosed) and want to know if it would be ok to install these if I clear as much insulation away from the down lighters from below as I can (by putting my hand up through the holes). Or will I have to lift the floor in the bed room above and remove the loft insulation completely.
