I am replacing incandescent downlighters with LED downlighters. There are six in total.
When I removed the current down lighters I noticed they were wired up such that there was a live and a neutral going from the dowlighter to a terminal block. Into the terminal block from the other side there are two live, two neutral and a ground. (No ground going from the terminal block to the current down lighter).
I am installing 240v GU10 LED dowlighters and the instructions state I can't wire them direct into a loop. I have two questions.
1. Can I wire them as the current down lighters are wired I.E. A live and a neutral coming from the terminal block?
2. Do I have to ensure the new down lighter has a ground running to it?
Thanks in anticipation.
