Depends on the span and spacings of the joists. And whether or not any of the joists carry any extra loads from dormer walls and the roof.Im doing a loft conversion. I have the steel in but just need to know the minimum joists I can put in. The plans say 9" but is 9" the minimum?
In that case, without the middle steel, the span is 4.7m so 9"x2" joists are the minimum if using C16 timber.
Although, if you close up the centres to 350mm and use C24 timber, you will get away with 8"x2" joists. Don't know if that is of any help to you?
Hey leeco, for a moment then I thought I was going to get my 100th "thanks"!
Come on, don't be shy![]()
Or rather than using traditional joists, why not look at engineered joists ?
Open web joists will span that easily @ 400mm centers. And will give you a stiffer feeling floor.
Forgot to mention they would be 202mm deep too.
Presumably that section of the roof is not being altered? If so, they may have decided it's simpler to leave the purlin where it is rather than allow the rafters to span onto the dormer wall and then put extra load onto the new beam.Why would the architect want me to keep the old hip and purlin and prop them up? I have ripped most of the old roof totaly off.
