- Joined
- 25 Nov 2013
- Messages
- 63
- Reaction score
- 0
- Country
Hey All, I bought a house its a fairly old one but the attic has tons of potential. One thing the ceiling in the upstairs landing is sagging and its because when I went to the loft it was holding 3 x 8foot doors on 3 beams over an unsupported 15 foot span on 2x4 timbers.
Thanks to the previous owner for that. I removed the load and will repair the ceiling soon however as the timbers have been bent I dont really want to use them again.
Heres where I need your thoughts
I am planning to make a ledger board of 1 x 6 or something to run along my gable wall. And then put on that joist hangers that can support some spans of wood to the nearest load bearing wall.
Its not to make the loft habitable its to enable me to get into the loft safely without further stressing the older timbers.
The question I have is:
What type of timber do I need (2x6) would that be sufficient?
What type of coach bolts should I use presumably M10?
What type of timber thickness should I use to span a 6 foot gap?
Would a ledger board support a load on it temporarily around 120kg?
I just worry that I will build this frame on a load bearing wall but the ledger board pops out of the bricks.
As I say this is not to be used as storage its to give better access to the attc so I can also sister the old bowed timbers. Think of it as a floor on top of a floor.
