I need to insulate the suspended floor between the garage and the bedrooms above.
The joists ar 220mm deep so there is plenty of room for insulation.
The floor area is roughly 21 m sq.
I could fit 100mm celotex in the voids, or for significantly less money I could get 200mm loft insulation in there.
(Wickes are doing 200mm loft insulation for what works out at £2.08 per m sq ) and so for about £50 I could stuff the floor full of it.
100mm Celotex will work out at about 6 times that !
I know that I would need a waterproof membrane if I went for the loft insulation, but I guess my real question is will 200mm of loft insulation offer enough of a thermal barrier.
Maybe the best overall plan would be 200mm of loft insulation in the voids, and then 25mm or 40mm Celotex under the rafters. That would cost about half as much as just going for 100mm of Celotex.
I don't mind paying for the more expensive insulation, if there is a definite advantage, but I am keen to save as much money as possible at the same time.
Any advice will be gladly received.
Cheers
Gary
Cheers
Gary
