Long run to outside tap
19 Jan 2006
West Midlands
Just in the process of replacing my conservatory.
As part of this, I need to move the current tap from one side wall (bottom right in the picture below) to another (long story but there is a good reason).
To do this I will need to go up and over a doorway and hopefully down into a cavity and through the wall to the outside. Probably look at a 3m to 4m run. I was planning on ring soldering the pipework (need to learn this skill), as it will be boarded over. Also to avoid any damage in future, I was thinking of taking it up to the conservatory roofline, so that it is out of the way for most of the run (this may add an extra metre or so).
Does anyone see any major problem with what I'm proposing above. I may need to think about expansion given the potential temperature extremes in summer, etc.
Any views much appreciated.
Many thanks,
Damian
