I need some advice here as I don't know know if this is a problem or if it is acceptable performance.
From cold, the timer switches on, the boiler goes through its quick check, flue fan kicks in and the pilot sparks all as normal. Now comes the problem. It is taking at least 4 minutes of sparking for the Pilot to ignite sometimes much longer. As soon as the Pilot eventually lights, the main burner fires up almost straight away and radiators heat up as normal. After this, the pilot only takes a second or two light.
The problem seems to be getting worse in the last few days taking longer and longer for the pilot to light.
I don't remember it taking so long before. The spark seems fairly bright as usual. I would have thought any spark + gas = ignition. The gap the spark jumps is about 12mm.
Questions.
a) Is this spark gap enough?
b) How strong does the spark have to be?
c) Is this normal or perfectly acceptable to let the boiler spark away for so long?.
I don't want to sound paranoid but with small children (2 of which are unwell) and cold weather, I want to avoid a breakdown and keep the heating downtime to a minimum.
I have a Potterton Prima 80F Boiler about 14 years old, in an open vented system is it helps.
Questions.
