The missus has converted the area under the stairs (to loft) in my daughter's bedroom into a den/snug kind of thing. At the moment there is a socket fed wall lamp in there with a switch on the cable fed from a double socket.
My daughter is very young with inquisitve little fingers and also likes to pull at the cabel,so I would like to run
a) the lamp off a switched fcu with a blank plate next to it so the lamp would run from the switch on the socket.
or
b)lamp from fcu and use the switch already provided on the cable with a blank plate
or
c)use an fcu with socket and just use one of those plastic baby guards.
So, the question is can you get any kind of fcu/blank plate patraces?
Failing that, can you change the fuse on the cooker switch/socket patraces to a smaller 3amp one?
Hope this makes sense.
or
or
