looking for some advice really on decking problem
23 Jan 2008
Coventry
I did decking job earlier in the year at the end of a customers garden
one shed on the left which i decked around.
got a call weeks later saying they got puddling on the decking but doesnt want any holes drilled in it - so i left it for a while - but then i had trading standards on my case -
so i went round the next day (about two weeks ago) and tried to lift some of the boards up on the left hand side of the deck - puts some packers underneath to create a slight fall - so the water was no longer puddling.
now decking is usually for sitting on or having a bbq etc...
I thought about it afterwards. what has put a strain on it is they have put a big 8ftx 6ft childrens play-shed on it.
If i had known that - it would of strenthened the area a bit more just in case!
just missed a phonecall tonight off trading standards - could i give them a call - but i dont know yet if all at is ok like a follow up call or another issue.
So the question is - is it my problem that they havehad issues with the deck by putting the shed on it? - Do i have anything to stand my ground with !
Job price was approx £1300.
would love someones oppinion please & in the meantime I will upload a picture if i can.
Craig (Coventry)
heeelllooo craig melvin sorry to hear you problem
8x6 cildrens playshed about 300k-500kg
6 or 7 adults at a bbq 500-1000kg
did you leave a 4-6mm gap between boards
yes i left the gaps in between about 5mm so thats ok
I think if I new the shed was going to be put on there - I would have put either more support in or decked around it like i did the shed on the right.
The permanent weight of the shed has cause the deck to sink slighttly - not much but enough to create a bit of puddling. the customer is fedup with having to brush the water off.
It wasnt like this until they put this permanent shed on there! - it isnt light! - I couldnt push it out of the way or anything.
regards
Craig
assuming its pooling where the angle changes run a saw along the join to give a 2mm gap[circular saw thickness]3mm deeper than decking thickness
you may have to do it more than once
because the decking changes angles rather than spreading the load farther away the join is acting like a hinge so needs 50% more to twice as much support
http://www.diynot.com/network/craig melvin/albums/14149/52349
Should be able to handle a shed easy!
Not 100% familiar with decking work but if the ground aint hard clay soil then I would reckon you'd need a sub base with membrane in between the sub grade and sub base to stop any movement
