Lopro 10 underfloor heating
28 May 2009
Kent
Has anyone on here had any experience with the nu heat lopro10 underfloor heating as a retro fit to a concrete floor. Just wondering if there was any issues with it heating up or is all the heat lost into the concrete slab
Got it at home. Panels are flocking heavy. Worth putting some insulation underneath the panels.
panels have a solid slab with no insulation beneath it.
Works well.
Just be aware that the very small bore pipework used on these low profile systems is much more susceptable to blockage especially if your system has radiators too. Make sure the system has no leaks and is fully inhibited.
I think connecting onto a clean system is a little more important. Inhibitor prevents corrosion and doesn't magically make dirty systems clean like some installers out there think
Hi Gazdaz,
Did you ever get round to installing this system from Nu-heat? I am looking to retrofit on my concrete slab also and would appreciate any feedback you may have on this system. Were you able to add additional insulation underneath?
Thanks, OB
