I have a 2004 2.0L Turbo Diesel Zafira. It's always been pretty poky and when cruising at 60/70mph, could always power forward nicely when putting the foot down.
EGR packed up recently, where I had no power all the way through (it had been on it's way out for a while - used to regularly clean it every now and then). That made things better but the top end acceleration was still a problem.
Got engine management light coming on so called AA. AA man suggested changing the MAP sensor which I have done but that has made no difference. The error code was P0234 Boost pressure control "Control deviation positive".
With this sensor changed I haven't seen the engine management kicking in again but then I haven't pushed it.
I'm running out of ideas so worried that the turbo has now gone, which would spell the end of my lovely car (unless I can get a cheap one).
I checked all the pipes around the turbo and sucked on the waste gate vacuum pipe. The level moved fine.
So, firstly, anything else I can try other than the turbo. If it is the turbo, is there anyway I can fix it, get one cheap and how easy are they to replace?
Thanks all!!!
Thanks all!!!
