Boiler is a new ariston ACO 32 condensing combi with vertical flue.
Everything seems to be working, pressure is fine at 1-1.5bar etc,
no air in the system.
The only trouble is that it's making a very loud noise like a
trombone that builds up when the hot water tap is turned on and
then gradually fades away over a period of about 5-15 seconds.
(ie. the system is unstable and oscillates). This also seems to occur
when I turn on the central heating; ie there's no DHW draw off.
So that seems to suggest it's related to the gas burner.
If I keep drawing off water intermittently, I can get the warm system
to start without making the noise, and then everything works as
expected. If I listen carefully though, I can still hear faint
traces of the oscillation when the burner starts heating, so I know
that thing's still aren't quite right.
The boiler itself was idle for a year or so in it's box while
waiting to be installed. The pump was a little stiff, but seems
to be running freely now. The pipe runs in the system are all
pretty short since the boiler is very close to the bathroom/kitchen.
The mains pressure water is fed through a non-return valve, to
a water softener and finally to the boiler.
Does anyone have any suggestions as to the cause?
Thanks,
Mark.
Thanks,
Mark.
