Need some expert advice on my home.
I bought it in April. Its a 3 bed semi rendered 1930's house, and is in disrepair.
No heating system was fitted in the property, other than an immersion heater for the shower and taps.
what I have done so far
I put a new roof up over the summer ( inc air tight membrane.) And had planned to do external wall insulation and a MVHR unit with a heating element for the heating, along with keeping the electric immersion heater for hot water that was already fitted.
It seams the external wall insulation is not happening now as I cannot for the level I wanted too under the 'green deal', and funding has also been reduced.
The mvhr system is also looking too problematic to install.
the problem
I bought a power shower and pump, along with a cold water tank to run the bathroom, which are partially fitted.
But I need to rethink the whole heating system, and I'm worried that I will need to take them back out as the best answer will be to install a combi boiler.
What should I do??
The only cheap to run alternative I can think of is a air source heat pump attached to a water tank, by I don't think I can get heating payments back as I have a gas supply to the house.?
the problem
What should I do??
