Low hot pressure on sealed system
jfk
27 Jul 2007
Bournemouth
Hi ive just changed a bathroom suite on a bungalow that has a sealed hot water cylinder. The plumbing in the house is old including the cylinder. When turning the hot water back on the hot water dousnt maintain pressure. When turning the hot water taps on their is a sudden burst of mains pressure wich the dwindles in to a very low pressure run. Any ideas on what is causing this and how to rectify. Cheers J
have you gone from low pressure to high pressure taps?
whats a sealed h/w cylinder ?
"its old"
why is it delivering mains pressure hot water ?
air lock ?
The initial surge is the air bubble expansion dissipating.
After a few seconds the air charge is used up and your flow rate drops to what is coming up the road.
If this doesn't affect the cold then the unvented has not been fitted with a balanced cold off the combi valve, and the strainer in the valve is most likely partially blocked.
