Hi, I'm hoping someone can offer some advice on this problem please.
I've just installed a low level cistern and pan, where the two are connected via a plastic L shaped pipe. When I first installed it, the flush was perfect, covering the whole inside of the pan. However, due to a slight leak on the flush pipe connector I had to disconnect everything and re-connect. After doing this, the flush appears to have changed, and doesn't cover the top 5 inches of the front of the pan. I'm baffled as to what I've done different on re-connecting that has forced the flush pattern to change. Has anyone come across this before - is it to do with the angle that the pipe makes to the cistern and pan?
Many thanks,
Jeff.
Many thanks,
Jeff.
