keep getting F0 fault on my jaguar boiler but pressure is ok if i try to charge the system it suddenly jumps to 3-4 bar have changed pressure switch but still have same problem has anyone got any idea's.
NO NO SEPARATE GAUGE BUT ONLY HAVE JUST SLIGHTLY OPEN THE FILL TAP AND PRESSURE SUDDENLY JUMPS. WHERE NORMALLY YOU WOULD HEAR THE SYSTEM FILL AND COME UP GRADUALLY.
Get a suitable gauge and make it into a radiator fit into the blanking plug you may need a brass bush but that is dependent on what type of gauge you buy
This will give you an accurate reading of the sealed systems water pressure
