I have fitted a Mira power shower, cold only, straight from the mains and found the water pressure is not good. Will fitting a pump help if so suggestions as to what one.
my niece just moved into the maisonette and the electric shower
that aws there did not work so we installed a new one in its place.
assumed the water pressure would be ok. What would be the answer.
