Low spot on gutter, Manchester
23 Feb 2016
I have one bit of gutter that overflows when it rains. It holds water so its definitely a low spot around the bay window, right on the corner where it sticks out.
Anyone in and around Manchester that can come and fix it. Its not something i can be bothered doing myself at the minute i would most likely just make it worse.
Rob this is a DIY site, not find a handyman service.
Post some pictures and we can help you or open your local paper.
Andy
Andy
Okay, how do you fix a sagging gutter then. I'm not even sure how the brackets attach to the fascia boards, do they just screw into the plastic or do they fix to something behind.
Unfortunately a common area for leaks/overflowing. The brackets do screw into the fascia so hidden by the gutter. No one with any sense would attempt access from a ladder - so you could hire a tower scaffold and diy. A decent tradesman would use/charge for one.
I hope your joking regards the ladder. Surely it's not much more difficult than cleaning the gutters.
So do I have to unclipped the gutter or something then unscrew lift then screw it back.
if its standard plastic gutter unclip it and take it down, then unscrew the bracket
that you need to higher and screw it in a bit higher then clip the gutter back.
