Hi - have had a low voltage light for about 3 years - looks a bit like this one:
http://www.argos.co.uk/static/Product/partNumber/0021993/Trail/searchtext>LIGHT.htm
recently, have decorated the dining rooms and fitted this light back, with a dimmer from screwfix:
http://www.screwfix.com/search.do;j...CSTHZOCFFI?_dyncharset=UTF-8&fh_search=96836.
So the light has 5 x 20w 12v G4 and the dimmer is 500W suitable for low and mains volts.
Trouble is though when you switch the light on it pulses at about 1/2 brightness.
Any ideas what the problem is? - dimmer works fine with a standard bulb. Have I got the wrong dimmer or is the light fitting not dimmable?.
Can you get non halogen g4 bulbs and would it make any difference?
Thanks in advance
Thanks in advance
