Lowering a ceiling
5 May 2010
I'm looking to lower my bathroom ceiling by about 4 inches to hide an exposed beam (not the right word) in the corner of the room.
I was wondering what would be the easiest/cheapest way to do it.
I was thinking of attaching 4x2 at 90 degrees to the ceiling joists at centres to match the plaster board.
I'm finishing the ceiling with these http://www.decorcladding.co.uk/acat..._Ceiling_Panelling_Decor_Cladding_Panels.html
So was wondering would it still need a skim before I put them up?
and what would be the best way to attach the 4x2 to the joists, skewed nails/screws?
Or is there a better way altogether of going about it?
The room is about 5 x 7 1/2 foot btw.
Thanks in advance
Ralph
i personaly would go for 2x2" along the length screwed to the wall another length central breaking the span 2ft6"
2x2" every 22 to 24" along the room 2 inches off the wall at each end [first and last batton]this reduces the chance off splitting the tounge when blind nailing wood
centres at 3" 24" 45" 66" and 87"
Thanks Big-all, would you finish that off with plaster board and skim or are you saying you'd just attach the pvc cladding to that?
Just reread your reply and I'm not sure how your supporting the central length. Would that just be skewed into the wall at either end, then supported by the cross pieces?
screwed through the ceiling into the joists
you need to check if theres any fire safety issues with a void!!
