Hi there,
I moved to my current 1950s house last year which has a flat roof with little are no insulation inside it & during the cold nights i decided i would try insulate the roof from under the plaster board ceiling to try make things better next year,
I`ve thought of attaching 47x50mm timber across the ceiling joists using 120mm screws at 450mm intervals & then putting celotex 50mm between the 47x50mm timber battens & then attach 12.5mm plasterboard over that.
Just wondering if the ceiling/roof joists will hold the extra weight of the battens / celotex / plasterboard the joists are 2inchs by 9inchs on 18inch centres
Any Help Advice Would Be Great
Thanks..
Thanks..
