lutron grafik eye
24 Mar 2006
Suggestions please.....I'm fitting a Lutron controller which has 6 live connections, one for each circuit. However there's only one connection for earth and neutral so I was wondering what the neatest safest way of connecting 6 earths and 6 neutrals presumably within the wall box. Something like you use in a consumer unit would seem to make sense to me.
thanks.....Jim
Jim, you've got me confused :?
If you have 6 cables at your controller, 1 for each lighting circuit they must be switched lives. You also have 6 neutrals to the lights which you want to join.
You must (I hope) have a separate live and neutral feed at the controller making the total 7?
I had considered that......so to make the connections with those is acceptable in terms of the regulations and there's not a risk that because they are 'loose' in the back box they could come into contact with something they shouldn't?
It comes with an american wall box which is enormous........
