m3 screws
18 Nov 2005
fellas,
looking for the m3 screws that have the end like a standard screw and the top half is posi looking, they might not be called m3, come to think of it.
What are they for?
Normal backboxes use M3.5 machine screws, are they smaller than these?
they are for back boxes, but sometimes the lugs dont take normal m3, so these come in very handy. ??
All back boses are 3.5mm as far as I'm aware in the olden days the screws used were 2ba I think, you could always get yourself a 3.5mm tap and retap the thread?
thanks fattony.
its not the screws that are the problem, its the old backboxes.
At present i have sorted the offending backboxes, but in future i want to have these screws..
PS, i know they exist because i have used them before.
If it is for standard back boxes.....
M3.5 is the standard. Nothing else.
Old school back boxes are likely to be 4BA - slightly smaller than the equiv M3.5. As said, either save 4BA screws when re-wiring old places, or re-tap the 4BA hole with an M3.5 tap - These are available at all good wholesalers.
Conduit boxes use M4 screws, and the old ones where 2BA I recall - Again, slightly smaller than todays equiv. Again, I always save the old 4BA ones where I can.
you can still buy BA screws and they are handy to have if you work on places with old Besa boxes. Some people :) still have a box on the garage shelf.
2BA was the old conduit box size, slightly BIGGER than 4mm and nearly 5mm.
It as far as I know, was not used for backboxes , the screws would possibly not go through the fixing holes in the accesories.
Socket boxes used to be 4BA (2BA was conduit boxes)
I just rethread any old boxes I come across. Much easier than faffing about looking for imperial screws.
Rethreaderer
BA threads are still alive and well, even if they have moved to a home for retired threads living in reduced circumstances.
A model engineering supplier can usually supply all the even number sizes, as well an the non-preferred odd number sizes.
I would go along with tapping out 4BA to the 3.5mm standard.
A tap can also help restore stripped threads in a lug. Give the lug a good squeeze with a pair of mole grips or the like, and it often deforms the hole enough to take a re-tapped thread.
