Machine wont complete a cycle
24 Nov 2011
Please help! Machine would not complete a cycle and it was suggested i changed the brushes. Did so and problem still exhisted. As putting machine back together it was noted that one of the wires that was going into the connector had come out. This connector has many wires going into and out and connects to the motor. The wire was put back in but must have worked loose again. Can this conector be replaced, can the wire be soldered in any suggestions. Also when the machine was working and was switched off there was water still coming into the machine?
