magnetic reed front door alarm
16 Jan 2005
:oops:
Hi - Have fault showing up on alarm panel - noticed the magnetic reed on front door - cabling appeared slack - took it off
The cable is 4 core - black red blue and yellow - the cable going in are all connected to 4 of the 5 available connections on the reed
the cable going out to the next - a window connection - which works by vibration has only the blue and yellow connected - the red and black are not attached but do not appear to have been connected - i could be wrong
Should all cables be connected to complete the alarm system
please advise
regards
:oops:
These devices should and prob will be wired to different circuits on your control unit the vibration device will pos go to a small pcb inside the control unit this is to analyze the vibrations. So what you say are wired sounds correct.
:oops:
Hi
Not quite certain what you mean
Should I be connecting the two (red + Black) leads that are not connected to the red and black connections on the reed unit to complete the circuit.
Also I have a pir in this location - so to prove if this reed is faulty if i disconnect all and wire them all ie red to red black to black etc with block connectors should this complete the circuit for testing
regards
ps
thanks for prompt response
:oops:
If your vibration detector is an Inertia type (old) it does not need 12v
If your vibration detector is a Viper type (newer) it does need 12v
