mains powered LED lights
8 Sep 2015
Is it possible to buy a LED strip light system that you can connect to the main light in the room so both switch in via the same switch. I want to put the strip behind coving but don't want it plugged in to a socket like most systems available online
You can buy LED strips, you can buy 12V power supplies and you can connect such into your lighting circuit.
