Mains water kitchen Tap Hammering
22 Mar 2006
Yorkshire
Hi All
This thing is driving me mad and I am upsetting my family. I tell them to slowly shut cold water tap. Grown ups do but my young ones won't. I have tried reducing mains pressure it stops for a little while but doesn't cure the problem. So my expert friends what is causing hammering. Can I sort it out. Thank you in advance.
Just loose water pipe(s). Usually only the mains cold. With a combi, the hot can contribute as well.
Just clip them
Pressure reducing valve :idea: shutting stopcock redces flow -not pressure :wink:
It doesn't reduce the static pressure.... The more flow restriction you have the more the pressure (and therefore flow) will fall when you try to take flow from downstream of the restriction. . :wink:
