We have had the local water company approve the replacement of the mains lead water pipe in the property.
The advise was to use a 32mm MDPE pipe because it would give better flow into the property. My confusion comes when you terminate the 32mm in the property with a 32mm stopcock then what do you take from it?
Secondly would you use pexpipe instead of standard copper tubing to take it and burry the pipe into a wall to go upstairs (aprox 10 meters) to a unvented cylinder?
