Makin a door for roof area
31 Aug 2005
I have this small area, and wish to fit a weather proof door, it measures about 62cm square. What would i make the door out of?
TIA
whys that then
it can bee done most window firms will make too size
if you make the door from wood you`ll be forever maintaining it :cry: gotta be a uPVC firm :wink:
I could not see the picture at first so posted saying the picture was broken but then I reloaded and it came up (did you edit it?), there does not seem to be anyway to delete a post here so I just deleted the post so it was meaningless.
There's no reason, other than the maintenance aspect, why you can't make your own door out of wood. It will be much cheaper than a custom made UPVC one and provided it is well painted in the first place, will last a good few years before it needs doing again.
No youll find the image is rendered from the external source, depending on where you are occasionaly your browser may finish rendering the page and timeout fetching the image causin a blank page instead of the image.
