I have a tile cutter, but I suspect it was designed for when tiles where smaller. It seems tiles are getting bigger.
I plan to move houses, so I need something which I can use again.
So I don't mind if I can get one, which can cut tiles bigger then 600mm. The tiles I am going to use at the moment are 600mm....
I have read reviews of 1000m tiles cutter, but most seem to have low star ratings. So I am confused.
Example:
Selco - Tile Rite 1000 manual tile cutter rated 2.5 stars
Vitex - manual tile cutter 900mm rated 3.5 stars
I know on the other post someone recommended the Tool Station Electric tile cutter, however, I know if I give it to the builder (I mean handyman).
He will complain that it takes too long to cut and it will create a lot of dust (even though it is wet). He has used an angle grinder in the past, but he wasn't so keen due to dust on the newly painted kitchen...
Example:
