marble wall tiles
17 Feb 2009
Bristol
I'm hoping to tile my bathroom with marble tiles (10 mm thick). The walls are plaster which seems sound and i'd like to stick the tiles directly to the wall. Around a new shower i intend to use a Mira tanking kit and a classi seal tape to keep the moisture away from the plaster. Any advice , hints and things to avoid?. :?:
One thing to keep in mind is that you can't use most bathroom cleaners on marble tiles -- they remove limescale, and thus damage marble. I did glorious marble tiles in my last bathroom, and would never do it again! There may be some kind of sealant you can use, but I couldn't find one at the time.
Just as i thought i'd sorted out what tiles to use!. I hadn't given removing limescale a thought and i live in a hard water area - plays havoc with ceramic disk taps- anybody any comments on effective sealers for the tiles?.
Decorative concrete in teh newst most innovative way to get the look you want. Through use dye and superior new technology, concrete is used to create the look duplicating granite, slate, stone, brick and even wood.
