    Dismiss Notice
Masking tape trauma!
Discussion in 'Decorating and Painting' started by Beverly27, 22 Apr 2019.
  1. Beverly27
    Beverly27
    21 Feb 2019
    76
    Thanks Received:
    Country:
    Our house has been renovated and I really wanted to decorate, so that I can learn a useful skill and save my husband and I some money. Things have been going well, apart from with the masking tape which has consistently pulled the paint from the newly decorated ceilings. I've been using Johnstone's matt emulsion for the ceilings and yellow frog tape and I've tried leaving the ceiling paint to dry for 24 and 48 hours, but the paint still comes off. I know I can do this and I want to, I'm just very, very frustrated. Any advice you can give as to what I can do differently to stop this happening would make me very, very happy. Thanks![​IMG]
    [​IMG] [​IMG] [​IMG]
  2. Sponsored Links
  3. Notadecor8ter
    Notadecor8ter
    26 Jul 2015
    230
    Thanks Received:
    4
    Country:
    Is that new plaster? Looks like you haven't mist coated enough as yellow frog tape (if that's what it is) shouldn't take paint off that much at worse.
    However you have to cut in to ceilings from the wall with a steady brush, you can't do this with masking tape as you'll be asking for trouble.
    • Thanks Thanks x 1
  4. Beverly27
    Beverly27
    21 Feb 2019
    76
    Thanks Received:
    Country:
    Thanks so much Notadecor, it is new plaster and yellow frog tape. I put on 1 50/50 water/non vinyl matt paint mist coat first. Should I have used more coats or a different ratio for the mist coat, or both? What would you suggest I do now? My heart sinks when I think of having to remove all that paint, but the last thing I want is for the paint to peel off the ceiling.
  5. Beverly27
    Beverly27
    21 Feb 2019
    76
    Thanks Received:
    Country:
    Here's a video of one of the walls I painted 7 days ago, which had the initial 50/50 water/non vinyl matt mist coat. I'm scraping the paint off an area which I'd damaged, so no paint had peeled from here. I wonder whether the experts amongst you, Notadecor, think that this paint has adhered ok, as opposed to being a 'skin' on the new plasterboard. A first timer question I know. My heart's in my mouth.
  6. Notadecor8ter
    Notadecor8ter
    26 Jul 2015
    230
    Thanks Received:
    4
    Country:
    Best thing to do here is not panic and get stressed about it, its decorating nothing more!
    I have done a couple of mist coasts on new plaster, then watered down the normal paints then go into full paint.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. Mr Chibs
    Mr Chibs
    28 Jul 2015
    1,068
    Thanks Received:
    180
    Country:
    I use frog tape, and now, remove it once I've painted over it... yes whilst the paint is still wet.
    I've tried cheapo tape, pro-dec, but frog is still the best for me.
    • Thanks Thanks x 1
    • Like Like x 1
  9. gc1967
    gc1967
    18 Oct 2010
    113
    Thanks Received:
    22
    Bedford
    Country:
    Ratio for mist coating is usually 70/30 - you didnt mist coat with a vinyl matt did you, just use a contract matt emulsion watered down for a mist coat, also you should go to your local decorating centre and buy some Tesa masking tape, the yellow 1 they do can be left on surfaces for weeks and when removed no paint is pulled off.
  10. Beverly27
    Beverly27
    21 Feb 2019
    76
    Thanks Received:
    Country:
    Great advice, thank you!
  11. Beverly27
    Beverly27
    21 Feb 2019
    76
    Thanks Received:
    Country:
    I didn't use vinyl matt, thanks for the Tesa hint!
  12. wwwebber
    wwwebber
    5 May 2004
    435
    Thanks Received:
    24
    Country:
    I use a low tack masking tape for such things and take it off straight after painting - normally works out ok.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
