Hi
I am trying to source a module that will give control of an S plan system connected to two boilers. The master boiler is fueled by waste oil but if this boiler fails I want to automatically switch over to my convential boiler to continue to provide heating and hot water to my home. Has anyone ever used or seen a unit that will give this kind of control?
I was thinking of maybe using a pipe thermostat, relay and timer so that the switch wire from the S plan will power the oil boiler but if the stat does not detect heat after x amount of time then the relay will switch power to the conventional boiler.
Just a forethought to start with, would very much appreciate any comments, ideas or experience of similar systems
Many thanks
Many thanks
