One of the screws on my BT master socket faceplate just spins and spins and won't unscrew, so although I can unscrew one side the other side is still attached. I can pull it abut 1mm away from the backplate but that's it. If I pull hard then the backplate starts to come away from the wall.
This isn't a problem right now but I'm sure one day I'll need to access the test socket behind there.
Has this ever happenned to anyone before? Any tips on removing it? I obviously don't want to damage the socket as I believe this is technically BT's equipment.
