Mastic over grout
17 Apr 2024
About 36 hours after grouting a shower with a light grey grout, I ran some clear silicon down the vertical corners. The grout under the silicon now looks almost black (and has stayed like that for 3-4days now). So will the grout dry out back to light grey again at some point?
As above. It sounds like you used clear silicone. The grout colour will not revert back to light grey.
An epoxy grout would not have changed colour, but they can be a pig to work with.
Unfortunately, you need to try to remove the silicone and then use the right colour. From memory, Mapei sell at least 4 shades of grey
OP,
Your first mistake was getting grout into the silicone joints.
Your next mistake was applying silicone over grout - dont do that.
Now you have to clean out silicone & grout.
Always use a grout saw (or your knife) to clean out any grout from the tile grout joints, and then blow out any remaining particles.
Scrape the blade over your grout joint edges - do this to give clean tile edges for the silicone to grip on to.
