Good morning,
I have a rather annoying issue with my boiler at the moment and now its really cold outside the rooms are not reaching the temperature on the room stat.
The boiler will fire up and run until the leds on the panel reach 80ºC, the boiler will then shut off and start to cool down dropping back down the less on the panel until it gets to 40º - 50º Led then the boiler will fire up again and do the same process.
Recently the boiler has had new sensors on both the central heating and hot water sides as these were throwing a fault led previously. Boiler has also had a new diverter valve as the previous one had corroded and started to leak and a new grundfos pump has also been installed.
Has anyone come across this fault before, me and my plumber are running out of ideas at the moment.
Many thanks
Nick
Many thanks
Nick
