Maximum oscillating angle of Karcher OSCILLATING SPRINKLER OS 5.320 S
8 Dec 2014
Northamptonshire
does anyone know the maximum oscillating angle of the Karcher
Its not on the Karcher web site
Regards
It will depend on the water pressure and flow control on the sprinkler itself plus you will never get a sprinkler to lie completely flat on grass.
Wind and weather conditions also influence it.
Blup
Hi, I'll explain more.
I originally bought rotating ones and they didn't work. I then bought a cheepie oscillating sprinkler (£6) to try it out before buying a more expensive Karcher one. The cheepie just doesn't quite reach the extreme of my lawn by about 1.5m each end despite having a very good 4 bar pressure at the sprinkler. I noticed the cheepie has only a oscillating angle of about 50 deg from the horizontal. I would like to know if the Karcher has a slightly better oscillating angle before I spend out £32. even and extra 5 deg would do it I think. Thanks
Maximum reach is achieved at around 45 degree so no point them moving much beyond that.
If you can’t cover the area with one you use two or more.
If you're measuring from the horizontal, the spray will gradually go higher - not further - the greater the angle.
Blup
The Karcher Oscillating (recommended by my son) didn't work however I've now got a Karcher Pulsating revolving sprinkler and it works a treat. Thanks for your help.
Regards
