mazda 3213
4 Mar 2011
Merseyside
hi all
i've got a mazda 323,1.3,2002,it's done 42k miles
i bought mid feb,every thing works ok but in the boot
on left hand side if you lift up the boot mat to get at
the spear wheel it's wet under the mat,also to the left
there is a space you can fit your hand into,above rear
wheel arch,this is also full of water,i can't see any trails
to show how the water get's in there,i don't think it is
getting in from underneath,i don't have a clue how the
water is getting in there or how to stop it from happing.
any ideas please,i'm stumped
Common places to let water in are the tailgate rubber seal, and the seal around the rear lamp units......dry out the boot space as far as you can and play a hose pipe around the suspect areas.
John :)
John :)
thanks john
will try that,do yuo think black silicone wud seal between rubber around rear head light and car body if comming from there
I had exactly the same on my 323 Think it was a 2000 model, cant remember if I found the exact cause, I think it was where the rear light cluster bolts to the body work IIRC check that the rubber washers are in place and clean, I just put a shammy leather in the whole and absorbed the water from time to time
