MCB and cable identification
3 Feb 2007
Birmingham
I am looking to replace a broken shower unit, but want to check the size of wiring and the capacity of the MCB currentyly fitted - but I don't understand the markings
A new consumer unit has recently been fitted with RCD and MCB's
The MCB for the shower circuit is marked "B32 61/B32" - being old-fashioned I am more used to seeing something that says e.g. "40 amp"!.
The cable is marked "basec bs6004:2000(CH) IS201:2001 HAANI"
I think the HAANI may refer to the manufacturer.
Any ideas?
Without seeing the cable size, its install method and its length you must assume that a B32 mcb (32AMP) is the max allowable and this would limit you to a 7.5kw shower (dribbly on full heat) :(
Edit:Damn you 123 :wink:
That's great, thankyou, exactly the information I need to make sure that the replacement shower does not exceed the capacity of the wiring etc.
:D
