mcb trip why?
21 Aug 2009
Derbyshire
Hi - got one of those fancy ceiling lights that looks great but keeps tripping the MCB. It has 10 x 10w G4 lights with a 12v toroidal transformer. It is new fitting I've had in it's box about 1 year, but only recently put up after building works finished. I changed the fitting to normal pendant rose & everything o.k. So must be light fitting? - I want to test the fitting to find where the problem is as its past the guarantee time now and have been given a multimeter but am not sure how to test the transformer? If it is a duff one, can I replace the toroidal with same size electronic transformer or not? Haven't got enough money to call in electrician this close to Xmas and I would rather not have a bare bulb up for weeks on end!
Thanks. :confused:
Is it tripping on switch on or after a while?
Thanks - It is tripping on switching mostly, have checked the switch wiring - all o.k - and it is now switching a normal pendant rose without a hitch.
Ban-all-sheds: It is definitely the MCB. It is on a split load dual RCD board, but only the MCB on this circuit trips.
I have been told the toroidal type transformers are the least problematic so am thinking it is maybe faulty?
Probably just high inrush current which is a feature of toroidal transformers.
Either replace your MCB with a "Type C" or replace the toroidal transformer with electronic ones.
Frank
Frank
Thanks for the advice Frank - will try the transformer first and see if that resolves it.
